-Warrior Rear End-
Old Nov 24, 2002 | 02:13 AM
RaceWarrior350's Avatar
Default -Warrior Rear End-
Ok,
My warriors an 88 and i suspect that the rear end has never been redone and i would like to do it. Can i get an idea on cost and the parts im going to need???? And how long its going to take??? TIA
Later
Ryan
Old Nov 24, 2002 | 07:43 AM
WarriorManiac's Avatar
Ryan- Parts from Yamaha would be about $50. 2 bearings and seals. Would get more expensive if you have to replace the carrier of course. The hardest part is going to be beating the axle out if it has never been removed. I can change my axle in 30 minutes but it slides out easy. Add the time to pull and replace the bearings and seals I would say another 30 minutes the first time done.
Good Luck
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
