raptor reverse limiter
Old Dec 1, 2002 | 06:32 PM
xbox74's Avatar
Default raptor reverse limiter
any input on how to remove it?
Old Dec 1, 2002 | 07:18 PM
xbox74's Avatar
thanks
Old Dec 1, 2002 | 07:52 PM
RaptorRRC's Avatar
Just ground out the wire going to the switch in the case below the shifter and that will remove the switch from the system. There are two wires down there and one is a slip on and one has a philips screw. The reverse switch is the slip on.
Old Dec 1, 2002 | 08:06 PM
xbox74's Avatar
thank you very much
Old Feb 26, 2003 | 05:28 PM
JoeMillionare's Avatar
FYI: REVERSE LIMITER
Warning: Dangerous Modification
To bypass the reverse limiter on ALL model year Raptors is to cut the GREEN/WHITE wire
near the CDI box and ground this wire that goes into the ignition. This tells the CDI that
you are in a forward gear, however the ignition will not be able to turn on the
reverse indicator light.
-Joe
(not from the TV show)
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
