Throttle Missing when I hit GAS!!OR Climbing..Stutters!
Old Dec 9, 2002 | 01:32 PM
raptor03's Avatar
Default Throttle Missing when I hit GAS!!OR Climbing..Stutters!
WHen i go to take off i get a slight hesatation right in the begining of the powerband and then it's back to normal,Or when i climb it stutters alot ..Wondering if carbs are floating,and how do i fix it..Thanks
Old Dec 9, 2002 | 01:37 PM
warrior007's Avatar
I know alot of guys with the same problem, all with full exhausts and dynojet. Welcome to the club!!
The dynojet kit just dont work for some. I would try stock needles and springs but lower the clip 1 down from stock, leave the dj mains in and try it.
Old Dec 9, 2002 | 02:20 PM
raptor03's Avatar
Any suggestions guy's Thanks...
Old Dec 9, 2002 | 02:24 PM
BlueLeader's Avatar
I think you are too rich. what are your settings??
Old Dec 9, 2002 | 02:34 PM
raptor03's Avatar
150/155 makuni and i think 2 1/2 turns out, trimmed snorkel and 2 2 1/2 holes in airbox..the same specs. as in the dirtwheels shootout...Thanks..Hope you guy's can help..
Old Dec 9, 2002 | 02:44 PM
raptor03's Avatar
It only started doing it after i checked my sparlplug and checked my k&N filter,Sparkplug was a little black,But dident raplace it,Bike has been running fine till then and i have about 20 hrs on the system and never had a problem...
Old Dec 9, 2002 | 02:51 PM
BlueLeader's Avatar
You state 150/155 mikuni's, 2 2 1/2 holes in airboxbut your signature indicates Dynojet kit and no lid ???????????????????
HERE >>>>
160/165 mikuni, stock needles in 3rd slot, no lid.
or
148/150 dynojets, dynojet needle, 3rd slot, no lid. dynojet says 4th slot but mine ran better in 3rd at Glamis
that was my experience with an HMF slipon.
Old Dec 9, 2002 | 02:58 PM
raptor03's Avatar
I changed when i heard that it has too much turbalance when you run with no lid....Is it the jetting or what i did with the sparkplug and airfilter..How does your;s run with no lid..and there are 2 1/12 holes in airbox..Has been running great till the sparkplug pull and check yesterday..P.S how should the sparkplug look..Thanks..
Old Dec 9, 2002 | 05:58 PM
raptor03's Avatar
other suggestions are welcomed..thanks
Old Dec 9, 2002 | 08:12 PM
wshrdskin's Avatar
Sam,
are you running Mikuni main jets with Mikuni needles and Mikuni springs or Dynojets mains, needles, springs? Do not mix and match it does not work. With Dynojet and the 148/150 mains you can run with no lid with no problems. Your plug should be a Brown or Tan color not black. If you are running all Mikuni parts, try taking your lid off as you are running to rich apparently with the color of your plug. See how it runs with no lid.
Turbulance smurbulance, Once jetted correctly it will have more pull with no lid.
