Porting Carb Boots on Raptor!
Old Dec 13, 2002 | 02:40 PM
RaptorRider660R's Avatar
Default Porting Carb Boots on Raptor!
Who has done this? How have you done it? What tool did you use?
Thanks,
Nocando
Old Dec 13, 2002 | 04:54 PM
THEMOOSE's Avatar
I used a air grinder with a fine grit sanding wheel on it.
Pull the carbs, look & feel the insides of the boots & use a marker where the high spots are, slowly grind material away & do several test fits.
The boots have a little slop on the bolts so make sure you get it in the same place every time when you check it.
Go slow & do several checks & you can get it right on. Make sure the O rings are in the grooves correctly when you put it back together.
Old Dec 13, 2002 | 05:23 PM
660r420's Avatar
did this give you any more power that you know of, or if you could feel it?
Old Dec 13, 2002 | 05:26 PM
THEMOOSE's Avatar
Seat of the pants, No I couldn't tell a diffrence.
The theory is solid & I'm sure if I'd Dynoed it there would have been a small gain.
Old Dec 13, 2002 | 05:44 PM
660r420's Avatar
about how much time did this take, do you think it would help a raptor with a pipe, filter, and jets.
Old Dec 13, 2002 | 05:48 PM
THEMOOSE's Avatar
It was about 3 hours total time (About an hour porting & matching them) I did it while I was adjusting the valves since I already had the plastic off.
Any time you improve air flow it helps.
My boots were as much as 1/8" off in spots & that makes a lot of turbulance.
With CV carbs the less turbulance the better!!
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
