Yoshi on, hp increase is seen
Old Aug 11, 2003 | 12:13 AM
BigScary's Avatar
Default Yoshi on, hp increase is seen
I talked to a dynojet tech and I guess he didn't know what he was talkin bout.......
cuz he told me to do it one step lower than the sheet (mains)......he said it was wrong.......
I did it like the sheet said and it is perfect.......
he also said not to change the pilots......
my mods are listed below......and I am at about 600'
I am fixing to add a sparks X-6
what pilots should I be running?
Old Aug 11, 2003 | 03:42 AM
INSeaRChOFDUNez's Avatar
i had the dyno jets, and now i have the gytr and ill tell you that i had better performance with the gytr and no lid.
Old Aug 11, 2003 | 10:12 AM
PatsRaptor's Avatar
Sparks X-6 at 600 feet 27 pilots
Old Aug 11, 2003 | 10:15 AM
BigScary's Avatar
what about dial-a-jet?
is that worth the money?
Old Aug 11, 2003 | 10:16 AM
  #15
PatsRaptor's Avatar
Only if your going to change altitude alot like going from sea level to 5000 feet then back again
Old Aug 12, 2003 | 07:00 PM
  #16
wshrdskin's Avatar
BigScary,
You say you are running dyno jets and needles with main jet sizes of 146/148? With an 11:1 stock bore piston/Hotcam stage 1 and port job? This sounds BigScary [img]i/expressions/face-icon-small-wink.gif[/img] lean to me. The 146/148 below 3000' is for a pipe kit and air box mod. You've added compression and and added a performance cam along with cleaning the ports to increase flow. My guess is you need to be at 160/165 or 165/170 for 600' elevation.
Old Aug 12, 2003 | 07:18 PM
  #17
BigScary's Avatar
LoL
I dunno
I will take a look at my plug and see........but it runs good?
if I am running av fuel what color will it need to be?
the end of my pipe is white as hell?
Old Aug 12, 2003 | 07:46 PM
  #18
wshrdskin's Avatar
Any kind of race gas is going to clean things up and you won't get a good plug reading from it. My exhuast tip always cleans up when I run Ulitmate 4 or other type VP fuels. Normaly have the brownish to dark brownish disks then one ride with the ultimate 4 and they are a light gray or grayish color. I may be jetted rich at the 170/175 dyno jet mains I use but I feel more comfortable on the rich side than I do on the lean side. I obviously can't know for sure but 146/148 with your mods has got to be lean and it will run stronger lean, for a while.
Old Aug 12, 2003 | 08:00 PM
  #19
sixsixT's Avatar
Originally posted by: BigScary
LoL
That is scary.[img]i/expressions/face-icon-small-shocked.gif[/img]
2many2ride
Sep 27, 2015 04:35 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
metal249
Jul 24, 2015 01:00 PM
Jul 23, 2015 07:53 AM
ltrmc02
Jul 22, 2015 04:50 AM
