Wolverine ,Help......
Old Dec 27, 2002 | 07:23 AM
ZigZilla's Avatar
Default Wolverine ,Help......
My Wolverine's pipe is getting cherry red. Is this normal? I dont think it should be getting this hot. Anyone have any ideas?
Old Dec 27, 2002 | 11:12 AM
jcsact's Avatar
What are you doing when it turns cherry red? Mine has done it when I left it choked to warm up for about 15 min in a high idle. It also did it this weekend while I was playing in the snow because I was high in the revs blasting threw drifts. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 27, 2002 | 03:58 PM
ZigZilla's Avatar
All i did was start it up and let it warm up a while and the pipe turned cherry red.........i mean it was glowing!!!
Old Dec 27, 2002 | 04:46 PM
jcsact's Avatar
How long was it running? And was it at a high idle? If it was choked and idling high mine has done it also. I just pushed the choke in and it idled down and turned back to a normal color. This might sound like an odd question but were you in the dark when you noticed it?
Old Dec 27, 2002 | 06:15 PM
ZigZilla's Avatar
It was only runny about 10 minutes and yes i had the choke on to start it at first for a few minutes. And for your second Question, i was outside in the daylight....little bit of dark tree shadows both not dark
Old Dec 27, 2002 | 06:30 PM
jcsact's Avatar
The reason I asked if it was dark, is because both times I noticed mine was red it was in the early morning before the sun came up and in the evening. I just figured it was like that any other time I just never notice because it was sunny out and it didn't really show up. It might be running a little lean and getting hot. But I don't know enough to help you with that. I am carburetor stupid [img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 27, 2002 | 10:52 PM
SpDdEmOn's Avatar
I would say jcsact is probably right in that your jetting is lean and its making it run too hot. Ive never had that problem but thats probably what it is.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
