RAPTOR SWINGARM INSERTS
Old Dec 31, 2002 | 08:22 AM
mrexcitment's Avatar
Default RAPTOR SWINGARM INSERTS
My swingarm skidplate managed to pull both the threaded inserts out of the front holes on my swingarm and now the front of the skid plate just hangs loose the swingarm looks to thin to just tap for a bigger bolt so i was wondering if anyone had any ideas for me.
Old Dec 31, 2002 | 10:24 AM
tom18801's Avatar
put a heli coil in it
Old Dec 31, 2002 | 10:48 AM
FISHER1648's Avatar
I have the exact same problem....do ya think a helicoil will hold in the thin alum ? Also, the insert hole is all wallowed out and will not be useable with a different diameter hole in the swingarm....
Tom8801, did you fix yours this way and has it been working well ?
Old Dec 31, 2002 | 12:31 PM
THEMOOSE's Avatar
I've seen inserts that will fix them,
You drill the right size hole put an insert in & there is a tool that crimps it in.
It's a steel insert & there may not be enough room to use a heli coil.
Old Jan 2, 2003 | 10:46 AM
I found some inserts called knurled rivet nuts in the mcmaster-carr catalog that look like they will work so I think I'll order them and try that
bmxatv10
Oct 14, 2022 06:23 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
