raptor compression
Old Jan 4, 2003 | 04:52 PM
BONEshock's Avatar
Default raptor compression
stock compression is a little on the low side. if i were to put a 12:1 pistion in it what octane should i run, just higher octame pump gas or "race" gas?????
Old Jan 4, 2003 | 05:49 PM
RacinJason's Avatar
with that comp ratio I would suggest running a mix of about 100octane depending of course on your cam selection and then backing it down slowly until you need more
Old Jan 4, 2003 | 06:43 PM
BONEshock's Avatar
stock cam, the only thing that would change is the pipe, switch that out for a ct racing pipe
Old Jan 4, 2003 | 06:58 PM
PatsRaptor's Avatar
You will get more of a boost with also adding a cam
Old Jan 4, 2003 | 07:20 PM
BONEshock's Avatar
think i could get away with 92 octane????
Old Jan 4, 2003 | 07:25 PM
PatsRaptor's Avatar
Not with the 12.1 but 11.1 you can
Old Jan 4, 2003 | 07:31 PM
BONEshock's Avatar
what if i put in some sort of an octane booster???
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
