warrior electrical problems... HELP!!!
Old Apr 8, 2000 | 11:42 PM
ridewfo's Avatar
i got a 96 warrior, as i mentioned in another reply. here's the deal. when i turn the key on, there's no electric start, neutral light, or head/tail lights. so i have to jump the solenoid to start it. so i know the battery is good. when it's running, there's no neutral light unless the lights are on. and sometimes, if it's running, i hit the electric start (i know it's bad for it, but atleast it works), and i can hear the starter motor spinning. and when it's running, and the lights are on, they go dim when i give it gas. when it idles, the lights are normal brightness. when i give it any gas, the flicker and get dim. this is really frustrating me. and i cant afford $45/hr to have it fixed by a shop, so any suggestions would be greatly appreciated. thanx.
Old Apr 9, 2000 | 12:57 PM
Yamaholic's Avatar
sounds like a blown fuse.the one in the rubber plug above the tire on the sprocket side.that's what I'd suspect first anyway .....
good luck
Old Apr 9, 2000 | 09:38 PM
ridewfo's Avatar
the fuse isnt blown. maybe i should jus buy a new one anyway. someone told me it cold be blown down where i wouldnt see it visibly. is that true? could i just touch the two parts together and see if it will work, or will that ruin something too? thanx.
Old Apr 10, 2000 | 07:00 PM
deeznuts's Avatar
Sounds to me you either have a bad solenoid or a bad fuse. The fuse is cheaper I would change that first. My warrior had the same deal and it was the fuse. But if yours not blown I would check the connection in the fuse boot the wire may have come undone.
I would also check all the wiring for chaffing. you could have a bare wire that is grounding out.
Old Apr 11, 2000 | 11:45 PM
ridewfo's Avatar
the fuse in it was bad. the little piece of metal was broken off on both ends. so i replaced it and it still wasnt the problem. so atleast i got some of it. so now i gotta try and try again.
Old Apr 13, 2000 | 09:58 PM
ridewfo's Avatar
well, now here's the deal. the fuse helped with the lighting problem. for some reason, when i turn on the key, the lights will work without it running. and they dont get dimmer when i give it gas. so that's good. but the electric start and revere still dont work. im gonna have to take it to the shop. i just got $120 back in tax returns, so that should help.
Old Apr 14, 2000 | 10:50 PM
95TimberWolf's Avatar
check the connections comming from the start button all of the way back to the solenoid, or just do something that might help u even better, check all of the connections and wiring. i have a wire rubbing somewhere on my twolf and right now i dont feel like looking for it, but it least it still runs. i hope this helps u.
Old Apr 15, 2000 | 03:55 AM
wolfy's Avatar
I have the same problem with my 95 wolverine, I have a bad wire between the key and the solenoid. It's to much of a headache tracking it so i just bump start it.
Old Apr 15, 2000 | 06:45 AM
boomer's Avatar
How do you bump start the Wolverine?
Old Apr 15, 2000 | 08:53 PM
Y2K300EX's Avatar
I would think that you hold up the shift lever and push it down a hill and release the lever.
