bashee rear swing-arm/linkage zerks/seals?
Old Jan 15, 2003 | 01:18 AM
RIDEORDIEYZF's Avatar
Default bashee rear swing-arm/linkage zerks/seals?
I ride sand alot and greese my zerks every 2 or 3 rides. I was just wondering if every banshee gets greese around the seals? When i greese em i usually wipe off the excess bt after riding it seems to be a mes around the seals. I just redid all the s-arm and shock linkage bearings/bushings/seals too.
Thanks
Old Jan 15, 2003 | 01:52 AM
DunePilot858's Avatar
As the grease heats up it will leak out of the seals. Just keep wiping it off and pumping fresh grease into those zerks and your bearing should last a long time.
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
