Paddle Tires for Raptor
Old Jan 23, 2003 | 08:03 PM
rc3's Avatar
rc3
Default Paddle Tires for Raptor
I am getting paddles for my raptor, I have heard a couple different opinion's 20x10x10 9 blade haulers: 20X10X10 10 paddle Edges: and 21X10X10 9 blade haulers. What are your guy's opinions. I like to mostly hill climb with a little bit of drag racing and trails!
Old Jan 23, 2003 | 09:15 PM
maddog56's Avatar
if you want the best go with the skat trak extreme haulers. probably 20x10x10. 8 or 9 paddles stock, 10 paddles for a pipe. if you have some sizeable mods, go with 22" and 10 or 12 paddles. i have a stock 03 with 20-10-10 and 10 paddles. i dropped a tooth on my front sprocket to 12 and i am very happy. wiping the floor with piped banshees on 250yd hills.
Old Jan 23, 2003 | 10:19 PM
THEMOOSE's Avatar
IMO the best sand tire for the Raptor is Skat Trak 8 paddle Extreme Haulers in 22 x 11 x 10.
If your going to ride dunes with any size to them the Extremes will be the best choice.
No they don't turn like angled paddles & yes you'll need a front sand tire like mohawks to help with the turning, but if you have a wider than stock width the turning gets easier (I have 3" wheel spacers on the rear & it made a big diffrence).
I run the 8 paddle 22" Extremes with my piped & Jetted 02 Raptor & I can pull them great.
10 paddles will suck a lot of power on the top end in the higher gears, I tried 10 paddles & they launched & hooked great but I could tell they were a bit much for higher gears.
The 20's will reduce ground clearance & tend to dig holes more than 22's.
Old Jan 23, 2003 | 10:24 PM
yamaha4life's Avatar
from what i seen the 10 rim makes the tire lay flat and not much sidewall the 8" makes the tire
round out and dig more sidewall too takes impact of whoops
STLyamwar
Jul 25, 2020 04:44 AM
Aug 21, 2015 01:23 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
