Engine cutting out.......
Old Apr 12, 2000 | 09:04 PM
95TimberWolf's Avatar
i am having engine problems. i was riding from my uncles house to my on my t-wolf, which is not even a 1/4 mile apart. i was almost home, i was running 5th gear at full throttle and i was almost all the way home and the engine started to try quitting on me. what could it be? i thought mabey could my rings be worn out and it is building up oil and taking up and not letting enough fuel/air mix in. or could my CDI unit be out. any suggestions are welcome! i need all the help i can right now, it has been like this for about almost a year now, and i really want to get it fixed soon! PLEASE HELP ME!!! THANKS!!!
Old Apr 12, 2000 | 10:29 PM
NoFear29's Avatar
With my warrior, if im wide open in 6th gear it will seem like it has popped out of gear. I was told this is some kind of built in rev-limiter. I don't know if this is the same problem, but if it is I was told it is normal.
Old Apr 13, 2000 | 09:22 PM
BurleyOne's Avatar
I would start by changing the plug and cleaning the carb good. If anything thats a good start.
Old Apr 14, 2000 | 12:03 PM
Harold's Avatar
check your float level, it could be too low, this can be done without removing the carb. !!
Old Apr 14, 2000 | 03:16 PM
i bought a new plug for it about a month ago and that is when it was doing it also. i cleaned the carb with carb and choke cleaner. before i restarted it back up i filled tthe float bowl up with carb and choke cleaner and that helped a lil bit. a friend told me that he thinks it might be my CDi unit or rev. limiter, or both. but i will try changing the fload level. but please keep giving me suggestions because i need all of them that i can get. i will let u know if changing the float level helped out or not. i probally will change it tonight and i will let u know by sometime tomorrow. Thanks!!!
Old Apr 14, 2000 | 05:41 PM
rhino99's Avatar
My 300EX cuts out at top end as well. It just starts kinda hesistating and sputtering. I have been told that I need to re-jet or that my revlimiter is kicking in. I think its the rev-limiter cause it sounds just like if I was trying to back up to fast.
Try putting it in reverse and running it full out till the rev-limiter kicks in, if its the same type of cutting out thats your problem.
Old Apr 14, 2000 | 07:45 PM
yes that is the exact same thing mine is doing, but it never did it before. i serously thing my rev limiter is shot. i checked my flow level it turned out to be ok. i pulled the plug and regapped it at about 4 thousands lager. helped very little. i also ran into a new probalem tonight. throttle jamming up, and i hadnt even drove through water with it yet. it nearly took me through 2 barbed wire fences twice, scared the s*** out of me! and i dont have any brakes so i have to get me a set sometime soon. when it would jam up if u took and shifted up into the highest gear it would unjam its self or if u kill the engine it will unjam its self right after u kill it. it is really starting to p*** me off!!!
Old Apr 15, 2000 | 03:15 PM
could my valve clearance be out and be need readjusting? Thanks!
Old Apr 15, 2000 | 08:47 PM
Y2K300EX's Avatar
Yeah that is probably your rev limiter. It isn't as noticiable in 5th like it is in reverse.
Old Apr 16, 2000 | 03:49 PM
UPDATE!!! yesterday when me adn one of my firends were riding it to a mushroom hunting spot we had to go about 3 miles. 1 mile through and it was ok, but after it i was riding it at half throttle in 5th gear and it started spittering and sputtering. but when we got there i figured when i let off the gasit would quit on me, but it didnt. i think there is something wrong in my valves. let me know what u think. thanx!
