What's Good For The RAPTOR?
Old Feb 2, 2003 | 09:34 PM
RapBoy's Avatar
Default What's Good For The RAPTOR?
have a website or any way i could read and look up some info on these parts???
Old Feb 2, 2003 | 09:35 PM
sixsixT's Avatar
You could do a cam and piston for $400 if you did the work yourself.
Old Feb 2, 2003 | 09:36 PM
yamaha4life's Avatar
do a search on the forum put je piston and hot cam for raptor many pages will come up
not the advertiser telling you what you want to hear but what ppl that are using it think
Old Feb 2, 2003 | 09:38 PM
RapBoy's Avatar
ok thanks guys keep the ideas coming if you have some more?
LOL
Old Feb 2, 2003 | 09:42 PM
  #15
if you had your pm turned on you could ask whitebread he has this setup
Old Feb 2, 2003 | 09:53 PM
  #16
BADBRONCO's Avatar
You will also want to get the header pipe to go along with the T-4
Old Feb 2, 2003 | 10:00 PM
  #17
RapBoy's Avatar
How does this sound HotCam for $120.00???
Here's some INFO
High performance racing cam, designed for use with stock valve springs and rockers. STAGE 1: excellent midrange and top-end INTAKE LIFT 8.5mm DURATION 254 EXHAUST LIFT 9.4mm DURATION 246 NO CORE REQUIRED STAGE 2 ALSO AVAILABLE BUT REQUIRES A SPRING KIT
Old Feb 2, 2003 | 10:47 PM
  #18
RapBoy's Avatar
Ahhhh hey guys i just found a cheap DMC exuast pipe hehe alien i think it is called hmmmmm is it worth buying???does it give some HP???
Old Feb 27, 2003 | 01:05 AM
  #19
WulfMan's Avatar
yes I have an alien and it is awesome..........where did youfind it..........I am looking for another one for my brother........
btw you will need to rejet
and I would recomend running with the airbox lid off
Old Feb 27, 2003 | 04:09 PM
  #20
whitebread's Avatar
get the 11:1 and the stage 1 hotcam and a manual and put it in yourself.it's very satisfying when you do it yourself,and when you get it all back together it will make your heart race when you get on it the first time.kind of like when you tag your,well you'll get that feeling when you hit the gas.
if you do it yourself go ahead and change the timing chain too.be sure to put loctite on the chain sprocket bolts.big headache if you dont.[img]i/expressions/face-icon-small-mad.gif[/img]
