raptor performance?
Old Feb 7, 2003 | 08:00 AM
ew660r's Avatar
Default raptor performance?
I have a 03 raptor. All I have done so far is put on an wb e-series, dyno jet kit and pro flow filter kit. I run it with no lid. I runs great, there are no misses or hesitation. What kind of gains would I see from a 10.75 piston and a stage 1 hot cam? And would I have to change the stock head pipe?
Old Feb 7, 2003 | 09:53 AM
XtremeRaptor's Avatar
The gains in performance are considerable with the Stage 1 and 10.75:1 piston. I don't think you'll have to change your headpipe. Hope this helps you out a little!!!! XR
Old Feb 7, 2003 | 01:54 PM
mugsy's Avatar
I am running a yoshi slip on , jet kit, kand n, and also hace the cam and 10.75 piston. I am running it with my lid on. I can't say I noticed a dramatic increase in horse power but it does seem to rev better and does feel like it has a few more horses. Would I do it again yes. I have three budies with similar mods who do not have the cam and piston and I am always to the top first. Hope this helps
Old Feb 7, 2003 | 03:44 PM
wshrdskin's Avatar
More than what you saw from the pipe/filter/jet kit.
Mugsy take the lid off and you should pick up a couple more ponies and a couple bike lengths more over your friends.
Old Feb 7, 2003 | 04:09 PM
mugsy's Avatar
I just worry about getting sand in my air box. Do you guys who run with your lid off have this problem. I just don't know if it is worth the risk. Maybe I will buy the screen filters that go over the holes if I drll holes in the lid of my air box
Old Feb 7, 2003 | 05:23 PM
wshrdskin's Avatar
Yes, Sand gets in the box. I use a K&N pro design filter with flange and an outerwear over the filter. They do make outer wear covers for the box also. I've never had anything get past the K&N filter. Nada. I've never seen a foriegn object inside the boots of my quad.
Old Feb 7, 2003 | 06:59 PM
sixsixT's Avatar
After riding a day and a half at Glamis almost nonstop I had very little sand in my filter and airbox. The area is well protected even without the lid on.
Old Feb 7, 2003 | 09:01 PM
XxDumontRaptorxX's Avatar
I just ran my quad last week at dumont, and had a stock filter in with: 11:1 wiesco piston (670cc), stage 2 web cam, dyno jet kit, big gun exhaust. i just got a pro flow put on last nite, and am wondering how much improvement i will get
Old Feb 7, 2003 | 09:23 PM
sixsixT's Avatar
Did you go up on your jets?
Old Feb 7, 2003 | 09:25 PM
185:180, i used to be 180/175 before filter, i was talking about the specs before i changed out the filters
