Dyna FS Programmable Ignition-14% hp boost
Old Feb 10, 2003 | 08:53 PM
14mins's Avatar
Default Dyna FS Programmable Ignition-14% hp boost
Blue- In the stock setting it is enhanced over the factory box. You should bump the octane a little and try it out, cautiosly. I like it and i ordered a new one for the 03 raptor.
Old Feb 11, 2003 | 11:17 PM
14mins's Avatar
trinity sells them
Old Feb 12, 2003 | 03:21 AM
14mins's Avatar
Air- i do not think you will gain much using that cdi on your motor (62HP)
Old Feb 12, 2003 | 09:28 AM
garyc660R's Avatar
Originally posted by: KingRaptor
Since I actually use the product I would say the HP gains are are bit optimistic. The increase in spark and the flexibility to work with the timing makes very subtle improvements. However, for someone using a turbo or nitrous it is very helpful in retarding timing.Dipswitch Settings:Stock up upCurve 3 up dnCurve 2 dn upCurve 1 dn dn
Originally posted by: BlueLeadercan someone please tell me the switch combinations for the curves...curve 4 = both switches downcurve 1 =curve 2 =curve 3 =thanks
Which curves advance / retard timing in standard config? How many degrees? Thanks.
Old Feb 12, 2003 | 11:51 AM
  #15
garyc660R's Avatar
Thanks KR. I was planning on getting the ignition now and purchasing the programming software later. Do you remember what the "built-in" advance / retard curves were? How many degrees? I probably should have elaborated in my previous post.
Mikegriff92
Technical and How-To Articles
Oct 26, 2015 02:40 PM
Aug 18, 2015 01:00 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jun 8, 2015 11:05 PM
ShortyRock
Mar 22, 2001 11:29 PM
