Overheating Big Bear
Old Mar 3, 2003 | 05:51 PM
Ilovemymudder's Avatar
Default Overheating Big Bear
Hello fellow Yamma Dogs
My Big Bear 400 4x4 has been running hot - of course while running long distances and riding like it's a sport bike - bigger tires (27")
I keep the oil changed, oil filter clean, air filter serviced and so on
Any ideas?
Old Mar 3, 2003 | 06:02 PM
jdm's Avatar
jdm
What symptoms is it having when it is overheated?
Is it going dead or sputtering or ?
Is the oil cooler fan coming on?
Old Mar 4, 2003 | 03:08 PM
Honda4Ever's Avatar
Ya i have an 02 big bear 400 4x4 with 27 inch vampires all around and i don't overheat yet. I have once but not with these tires. But i also think its cause my snorkel and it might be running lean. I know its probably that causing it to get hot. My fan comes on every day if i ride for about an hour or less at speeds of 25-35mph just cruising around. I think my prob is my snorkel.
Old Mar 4, 2003 | 04:19 PM
the fan comes on when needed, but the oil light has been coming on, usually after a hard ride.
the engine does not studder or stall, but it "feels" hotter than usual
I should also say I have always used YamaLube oils
have a K&N and Supertrapp pipe
I took it to the dealer to adjust the jets.
any thoughts?
Old Mar 4, 2003 | 07:16 PM
miniblaster's Avatar
we have a bigbear, its all stock but the fan hardly ever comes on. we have never had any problems with overheating, and it is normally run pretty hard for long periods of time. i don't know what could cuase it to overheat, i've never experienced that problem
mini
Old Mar 4, 2003 | 10:49 PM
tackleberry's Avatar
I too had that problem, so I got some of the exhaust pipe fiberglass heat wrap and wrapped the exhaust. I also got a sheet of the manifold heat deflection fiberfoil stuff, and put it on the bottom side of my seat. Lastly, i got a neopreme seat cover from Cabela's for $20.00. this has made all the difference after a long hot summer run....the heat stuff came from "Thermo-tech", off a link to 24/7 auto parts if i remember correctly. wrapping the exhaust made the biggest difference. good luck.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 6, 2003 | 06:20 PM
thanks for the info Tackleberry
I'll look into that, maybe the pipe is the source, kinda makes sense...
Old Mar 6, 2003 | 06:31 PM
if THAT aint it, you might have the carb checked for proper jetting, I've heard they can sometimes run rich...I've also heard that some carbs aren't tight at their attachment, loose bolt, or something like that. Also, a good coating of MUD (paint) cools it down....lol..good luck
Old Mar 10, 2003 | 07:22 PM
Thanks again, Tack.
I will check the carb attachment -
It was jetted by the Yamaha Dealer when I put the pipe and K&N on,
but that was some time ago - I have been thinking the packing in the pipe
(Supertrapp IDS 2) has burned up with all the riding I did on it, less back pressure would change things, too
Thanks again for the help,
Gary C
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
