Raptor problem
Old Mar 10, 2003 | 11:39 PM
wildwildweb16's Avatar
Default Raptor problem
what wires and what switch would be bad to make the starter do that?
Old Mar 10, 2003 | 11:45 PM
warrior007's Avatar
mine tried to start on its own once, it was a bad relay. Luckily I was home.
Old Mar 10, 2003 | 11:49 PM
warrior007 what relay was it because that might be the same thing that this raptor is doing
Old Mar 11, 2003 | 12:00 AM
wshrdskin's Avatar
Adjust your clutch freeplay. When you pull in the clutch there should be a 1/8" - 1/4" gap between the lever and perch before you feel resistance. This will ensure the clutch is engaged all the way when riding. If there is no free play your clutch would be slipping because the clutch springs are not putting max pressure on the clutch plates etc.
Old Mar 11, 2003 | 12:04 AM
  #15
alright will try the play in the clutch.
<FONT face=Verdana size=1>wshrdskin. do you know anything about the starter problem?</FONT>
Old Mar 11, 2003 | 12:06 AM
  #16
warrior007's Avatar
Part number 28 on this fiche
Mine is a 2001, make sure they are the same if his is a diff year
Old Mar 11, 2003 | 12:12 AM
  #17
we both have 02 raptors so i will have to see if that part is the same
Old Mar 11, 2003 | 12:15 AM
  #18
expensive little relay too
Old Mar 11, 2003 | 12:22 AM
  #19
YamahaRaptor660R's Avatar
i was thinkin maybe it might be the cooling fan? i had a cooling fan on my polaris go bad and it sounded kinda like a starter. this would kinda make sense seein as it did this once it was hot and then you started it again cold and nothing happened.
just a guess thought if im wroung you guys can call me dumb.
Old Mar 11, 2003 | 09:40 AM
  #20
wshrdskin's Avatar
No, I don't know anything about your starter problem, sorry.
