Need Help Jetting
Old Mar 10, 2003 | 12:15 AM
shmave's Avatar
Default Need Help Jetting
I just bought a used 2001 raptor it has durablue axle and front wheel spacers, I just ordered a Curtis Sparks racing system, and a Pro Flow K&N kit, I want to remove the air box lid and i was wondering if any one has any thoughts on what size of jets I should use. I'm thinking 170/175 but don't know.
Old Mar 10, 2003 | 12:24 AM
RoostItUp's Avatar
That would be a good start on jets, keep in mind that you might need to adjust your pilots and needle too.
Old Mar 10, 2003 | 12:52 AM
sixsixT's Avatar
That would be close on the mains maybe a little rich.I would put 25 pilot jets in also. 2 1/2 turns out on the left carbs. mixture screw and 2 3/4 on the right one.3rd groove on the needles.Good luck.
desracers's Avatar
Shmave
Why don't you call Curtis Spark and ask them what the jetting set up.
Let them know if you did any mod on the engine, set up and altitude you are riding at. It will make your job easy and time to jet it.
That how I did when I got the LRD pipe and it was spot on after I call them.
Old Mar 10, 2003 | 02:38 PM
shmave's Avatar
I ride in north mo. mainly but go to the little sahara in olkahoma a couple of times a year, There is no engine mods on my bike, I havn't called Curtis Sparks directly but on the web they just say a dynojet kit is recommended, I will call them and find out for sure, thanks
01 raptor
durablue axle, front spacers
trail tech lights, computer
kenda geckos/on douglas rims
curtis sparks system
pro flow kit w/ k&n andouterwears
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
