opinions about 4x4 unlocker for wolverine
Old Mar 12, 2003 | 05:15 PM
wolverineracer446's Avatar
Default opinions about 4x4 unlocker for wolverine
im considering buying one for my wolverine. i would like to know if it is worth the money and how it helps the ride.
Old Mar 12, 2003 | 10:02 PM
Ty2's Avatar
Ty2
The WARN Co. just e-mailed me today with the part # for the 424 select for the Wolverine- it is 66056 for the 00-03 models - they have the 424 for the 95-99 models too. He said they go into production next week and I can put in an order with a local WARN dealer. If you are going to get an unlocker for the Wolverine I suggest you go with the WARN part and not the HIGHLIFTER unlocker which I bought and sent back because it was junk. The wolverine in two wheel drive is a blast to ride,powerslides,donuts and makes cornering in tight trail much easier- then pull the button on the WARN 424 and your back into 4wd on the fly.For the 280 dollars you spend it will be like having two quads.
2001 Wolverine
CHECK IT OUT
Old May 21, 2003 | 01:34 AM
blgowerlims's Avatar
The 95-99 Wolverine unlocker just replaces the drive shaft.. right? If that is the case can the 95-99 unlocker for the Wolverine be used on a 97 Big Bear? The shafts are the same OEM part numbers. Or is there more to it that just replacing the drive shafts?
Old May 21, 2003 | 10:05 AM
spike82228's Avatar
It just replaces the drive shaft, but there is some mounting hardware that may or may not fit correctly on the Big Bear.
Old May 21, 2003 | 10:08 AM
slowride1's Avatar
From what I see theres more than just replacing the shafts you need all new seals, ring clips,see if what is all needed in a installation and match up the part #'s
Old May 21, 2003 | 10:16 AM
CTATV's Avatar
there wasnt more replacing the shaft on my 2001 wolverine I did the 424 and I say it is a definate must have. I love it. i can powerslide for like 40 feet when cornering in a dry field. you wont be doing wheelies and the acceleration/ power isnt affected but the handling is a load different in the trails and other places where your horsing around
Old May 22, 2003 | 12:20 AM
spike82228's Avatar
All that needs to be done is to take out the front differential bolts, slide it forward, stock shaft slides out and then 424 slides in. You just reuse the stock protective boots and retaining rings from the stock shaft, and put them on the 424 shaft. It is very simple and takes maybe an hour to do the whole thing and mounting the cable.
Old May 27, 2003 | 01:20 PM
BomByDuDE's Avatar
If u want u could just take of ur front differencial. but it wont go in 4WD ever again. But hey it weill still go through some monstorus mud.
Ima Jew
Old May 27, 2003 | 01:44 PM
BigBearFX's Avatar
they are supposed to make the machine sportier, they probably do
Robinhood
Dec 26, 2015 10:28 AM
rgjackson
Sep 17, 2015 11:21 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
