Jetting Question
Old Mar 15, 2003 | 04:34 PM
WarriorMan05's Avatar
Default Jetting Question
I was wondering how to tell what my carb is jetted at? I have a pipe so it is not stock, and i wanted to change it for summer riding. Also what should I change it to for summer??
Thanks
Josh
Old Mar 18, 2003 | 12:31 AM
ctportedrap's Avatar
your going to have to pull off your float bowl and take out the main jet. There is a small number stamped on the jet. I use to have a warrior and it is very simple to take off your carb and the float bowl. If you need more info let me know.
Old Mar 18, 2003 | 12:35 AM
ok on my warrior i cannot get the main jet out... it is not the way it is supposed to be or something, so could u pm me w/ how to do this please??
thanks
josh
Old Mar 18, 2003 | 12:46 AM
why cant you get your main jet out. You should be able to use a flat blade screwdrive. Did you put it in originaly? If not, it might be crossed threaded................
Old Mar 18, 2003 | 06:23 PM
it is stock..i havent done anything to it. There is no slot to fit in a flathead screwdriver. On the new jets that i have to replace it they have it, so that is why i dont understand it
Old Mar 19, 2003 | 12:17 AM
Hazmaster's Avatar
Try a 6mm socket Haz
Old Mar 19, 2003 | 12:21 AM
i tried that, thats what the mechanic at the shop said to do when i asked him.... but still nothing...i donno what to do
Josh
Old Mar 19, 2003 | 12:30 AM
does the 6mm socket not fit or what.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
