Whats the point?
Old Mar 29, 2003 | 11:39 AM
iamchad2k5's Avatar
Default Whats the point?
why do we use cdi boxes?
Old Mar 29, 2003 | 01:00 PM
Batoutahell's Avatar
Basically it is the ignition box. An electronic ignition. It decides when the spark should occur depending on what the engine rpm is at. It can also contain a rev limiter, so when the engine hits a certain rpm it retards the timing, or cuts the spark out.
This is not explained very well, but I think you get the jist of it.
Aftermarket boxes can be programmed with different curves, for different fuels, or conditions.
Older cars used to have a points type ignition, when the distributor shaft moved past a certain place, the points would open and close, sending the signal to spark. Again this is a crude explanation, but I think it serves the purpose.
Bat
Old Mar 29, 2003 | 04:25 PM
iamchad2k5's Avatar
ok, ok. do we need to use them though
Old Mar 29, 2003 | 05:28 PM
yes
Old Mar 29, 2003 | 06:11 PM
RacinJason's Avatar
We could go back to using points...some of you younger members might not have ever had to mess with them so you don't know how great the CDI is
Old Mar 29, 2003 | 07:11 PM
iamchad2k5's Avatar
if we need them. then why did my friend rip all but 3 wires off his dirtbike? it still runs like it normally did. maybe better with all that weight gone! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 31, 2003 | 01:47 AM
maddog56's Avatar
RAPTORJAY, my 40's ferguson tractor has points, and I want to jump off a cliff everytime i think about them. Im a college student, so i am not old enough to have seen them put in new machines, but I have learned my history the hard way and also appreciate some of todays advancements.
Old Mar 31, 2003 | 02:10 AM
mrbones's Avatar
My Honda 1972 ATC90 had them. Pain in the a$$. Always had to adjust them. Same thing with my '79 RX-7. I think electric ignition came and saved us all in 1980.
ReconBayou
Oct 31, 2022 05:37 PM
Customer Service #1
May 15, 2020 08:46 AM
EIF
Apr 20, 2017 07:15 PM
bigred20653
Oct 2, 2015 10:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
