jets or jet kit, help????????!!!!!
Old Apr 1, 2003 | 01:07 AM
Hossblur's Avatar
Default jets or jet kit, help????????!!!!!
Tell me about the dial a jet, I am not familiar with it.
Old Apr 1, 2003 | 09:56 AM
sixsixT's Avatar
Thu August 29, 2002 7:42 AM
You will need 2 kits,one for each carb on the Raptor,but,yes,it does make jetting adjustments quick and no dissassembly required. By supplying highly vaporized fuel to fill in the gaps in the fuel droplets,it balances out the air/fuel mix,giving better throttle response and power throughout the rpm range,and is completely automatic,adds more/less fuel depending on the engine load and vacuum signal coming from the carb.
95 Wolverine,Wiseco 10.25:1 .040 over, 88 grind cam, ported,skid plates,Works shocks, 25" Maxxis Sur Tracks on .190 reinforced rims. 99 300EX(son's),full Ricochet a-arm,skid,and swing arm protected (soon to be modded)
Report this to a Moderator
Reply Quote Top Bottom Edit
BlueRulez
Auburn, California
Thu August 29, 2002 8:27 AM
Hardhitten-
The complete setup for the Raptor is right under $140.00. That's one dial per carb, plus 2 snorkel filters. It's a breeze to install, and it works great. Customer service and tech support was great. Lonn is the owner, and is more than happy to help you out. In fact, if you go with a k&n filter, full exhaust, remove flap from snorkel, you won't even have to rejet. Their system will fill in the lean spots. Additional mods to the airbox may require you to rejet. Anyway, I like the system, and I liked the way I was treated as a customer.
Old Apr 1, 2003 | 10:03 AM
Hossblur's Avatar
what is the general rule as far as when to rejet per thousand feet in altitude. I have heard every 3000 and every 5000. Which is true, what size or what rule, leaner or richer as you go up?
Old Apr 1, 2003 | 10:41 AM
sixsixT's Avatar
You need to go leaner on your jetting as you go up. There is less oxegen in the air as you go up so it will start running richer.3000' is a good rule of thumb but four strokes can tollerate it much better than two strokes. Another option to rejetting would be to put one or two holes in your airbox lid and cover them with a plug or tape when at lower elev. and remove them as you go up allowing your engine to suck in more air.
Old Apr 1, 2003 | 12:42 PM
  #15
raptor03's Avatar
how did it run with the secret weapon?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
