kodiak mods and hop ups?
Old Apr 2, 2003 | 06:11 PM
ATVmadman's Avatar
Default kodiak mods and hop ups?
what are some good mods and hop ups for a 2001 kodiak? i want good tires for mud/trail riding, a slip on and a good air filter. also rims and a lift kit. what are the best?
Old Apr 2, 2003 | 09:16 PM
HELLFISH's Avatar
I would go with a mbrp silencer or hmf the mbrp is polished stainless the hmf is aluminum,a pro-design clamp on filter adapter cause the regular k&n will tear around the seal,the jet kit a dyno-jet kit is a little better than the stock setup but not much,you could go 1 size bigger on the mikuni jet with a filter and silencer but the jetting will be according to your elevation so it's a trial and error thing,or a dial-a-jet that you can jet externally...tire's get some itp589's 25" or 26"any bigger and you can't turn'em in the mud and you will have to get a clutch kit to make up the loss of bottom end power lift stay away loss of handling is not worth it..rims itp c-series look great,but heavier than the stockers by 5lbs a peice. also a vito's timing advance key gives you a 4 degree timing advance for about $30.
Customer Service #1
May 15, 2020 08:46 AM
YankeeRebel
Oct 6, 2015 06:44 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
