banshee rear sprocket
Old Apr 5, 2003 | 02:53 PM
YZFBANSHEEKING's Avatar
Default banshee rear sprocket
I herd that you can improve the speed of your quad by replacing the stock rear sprocket with a smaller tooth sprocket, how many teeth should you go down on a Banshee? and how many links on the chain need to be taken off?
Old Apr 5, 2003 | 03:29 PM
WyoDuner's Avatar
It's a lot easier to just put a 1 tooth bigger sprocket on the front. Depending on your mods determines how much speed you will gain.... There's no firm answer.
Old Apr 5, 2003 | 07:15 PM
CREEPINGDEATH's Avatar
I use a 41 tooth rear, and get a little more top end.
Old Apr 6, 2003 | 12:13 AM
OutOfControl's Avatar
I thought 14-41 was stock gearing. If you run in the sand I would drop a tooth on the front and see how you like it. If it feels good add a couple to the rear. After all how fast do you need to go?
Old Apr 6, 2003 | 12:15 AM
desracers's Avatar
cheapest way is just go up on the front sprocket.....
You will gain a little more on the top end and lose a little on the low end.
Old Apr 6, 2003 | 02:52 PM
BansheeStephanie's Avatar
what would be the best for hill climbs?
Kaleb_00
Jun 1, 2016 09:15 AM
snowolson
Aug 31, 2015 03:51 PM
Dammar
Aug 26, 2015 07:12 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
