tell me what you think about this comparison chart on jets
i couldnt stop thinking about the mikuni vs dyno jet numbers that i saw on a chart so i researched and found the site that they came from .if you want to view these numbers and this flow rate chart go to (TCARIZONA.COM)and look on the page about the mikuni and dyno jet numbers and tell me if these numbers look right or if they are bogus.i am only looking into this further because if these numbers are right then my 155/160 mikunis on my 686 may not be as far off from what some others are running as i thought.as you can probably tell i am pretty particular about correct information especially when dealing with something like jetting so if these numbers are no good i will disregard this info.if anyone has a conversion chart with different numbers i would like to see it for comparison.thanks for reading my ramblings.
dune,
I'll belive it, as I KNOW terry, he's real sharp on the royal star & v max, both use mikuni carbs, bds 28's on v star 650 & royal star, larger on the v max..He helped me out a lot when it came to jetting my royal..
the chart is also on buttfungus's site as well..check in the ds650 section for a post..
