Dialing In Raptor
Old May 5, 2003 | 05:42 PM
  #31
garyc660R's Avatar
Default Dialing In Raptor
The last bit of power of course. You are close with no stumbles or hesitations.....but that does'nt necessarily mean you are dialed in for peak power...[img]i/expressions/face-icon-small-smile.gif[/img].
Old May 5, 2003 | 05:59 PM
  #32
shmoo's Avatar
What do you do to get that last bit of power?[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 5, 2003 | 11:44 PM
  #33
wildwildweb16's Avatar
Ya what does he do for the last bit of power. I want to know too.
Old May 6, 2003 | 12:16 PM
  #34
garyc660R's Avatar
You are very close, at this point you make small changes and see how the engine responds. Example....160-165 runs good....why not try 162.5-165 or 162.5-167.5? Put a thin shim under your needle (1 or both carbs) so you can maybe adjust you needles on the 3.5th notch nown from the top. After you are close, the possibility for more power is usually there.....you just have too find it....[img]i/expressions/face-icon-small-wink.gif[/img]. When you find it, will you realize you have it? Only if you know your machine!
Old May 6, 2003 | 01:56 PM
  #35
I didn't know they made jets that were 62.5 and 67.5. When you say putting a shim under the needle do you mean like a washer or something by the clip?
Old May 6, 2003 | 02:05 PM
  #36
garyc660R's Avatar
Yes, the smaller increment jet sizes are available.....only when you go over 200 can you not get the small round jets in the 2.5 increments. Yes, a small washer can be used for fine tuning under the needle clip when necessary. Parts store or a Wal/mart - Hone Depot usually will yield small washers after some digging around. Theres power in tuning in a particular combination. Later guys.
Old May 6, 2003 | 03:43 PM
  #37
Well that is some good info that i have never thought about before. Thanks
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
