What do each of the jets do?
Old Apr 24, 2003 | 07:04 PM
bigmackloud's Avatar
Default What do each of the jets do?
Hey,
alright, finally got to work on my carb today.
i found the air screw. i also discovered that i have a 150 main jet. (let i'm still lean??)
what i don't understand:
i saw what appeared to be 4 jets. one is obviously the main jet. right infront of the main jet was another jet in a tube, i'm guessing the pilot jet? then there were two other jets. one was located beside the float pin, and it appeared to go through the carb and stick out in the carb intake, like you can see it from the airbox side. the other jet was in towards the front of the carb, located in the bottom of the float bowl.
i also didn't see any jet needle that i could adjust.
can anybody explain what i've seen today?
thanks,
bigmac
Old Apr 25, 2003 | 02:04 AM
Hey,
checked my plug again, and maybe somebody can explain this. the curvered part of the electrod is white on top, then on the base of the tip, one side is white, the other is black. what's up with that? somehow i'm guessing it's probably not good.
any thoughts?
thanks,
bigmac
side note: my helmet was delivered today for DK. shipping time = 3 days. not too shabby!
Old Apr 25, 2003 | 01:24 PM
Hey,
where are all the warrior jetting pros? [img]i/expressions/face-icon-small-smile.gif[/img]
what i'd really like to know, is where is the needle clip that you adjust? i took the bowl off but didn't notice anything that looked adjustable.
thanks,
bigmac
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
