Raptor reverse limiter. I screwed up HELP!
Old Apr 27, 2003 | 06:15 PM
Guest
Guest
Posts: n/a
Default Raptor reverse limiter. I screwed up HELP!
Well i think I may have spliced the wrong wire. Heres what I did, 1) took the wire that did not have the phillips screw holding it down belowe the shifter, I followed the one that should have just popped off, I didnt take it off though, I just followed it up and spliced it higher (is that the right or wrong wire?) 2)spliced the wire, added wire to splice and grounded it on the airbox 3) waterproofed the splice, 4)put everything back together, Now my neutral light constantly stays on and the da#n reverse limiter is still there! Please help, this is making me mad, any help will be greatly appreciated, thanks
Patrick
Old Apr 27, 2003 | 06:36 PM
sixsixT's Avatar
Sounds to me like you grounded the wire for your neutral light.
Old Apr 27, 2003 | 07:34 PM
Guest
Guest
Posts: n/a
Well, you are correct, i followed the wire up but while traveling to the airbox I mistook it as the other wire, oh well, its all fixed,
Patrick
Njrider1230
Jul 29, 2023 05:16 AM
Aug 21, 2015 01:23 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Schneider
Jul 24, 2015 05:05 PM
black_thunder
Jul 22, 2015 06:01 PM
