170/175 jets for raptor
Old Apr 27, 2003 | 07:20 PM
sixsixT's Avatar
Default 170/175 jets for raptor
mikuni, the smaller one goes on the left or shifter side
Old Apr 27, 2003 | 07:25 PM
wildwildweb16's Avatar
would you recomend using the mikuni jets 165/170 or getting the equal size of dyno jet? Do they even make them?
Old Apr 27, 2003 | 08:36 PM
sixsixT's Avatar
I like the mikunis, wshrdskin seems to do good with the DJs. Either way you should get a kit with different needles.
Old Apr 28, 2003 | 03:27 PM
I already have the K&N jet kit so i have the new needles. I just want a bigger size main jet. I guess I will try the mikunis. I do have another question though. My friend has the same setup (pipe,header, jets) and when it he is running full out it runs great but if you just putt up a hill or in second gear it bogs down and wants to die. Bring the needle out more or what? something else wrong with it?
Old Apr 28, 2003 | 04:38 PM
  #15
anyone have any ideas on what is wrong?
Old Apr 28, 2003 | 09:37 PM
  #16
sixsixT's Avatar
If you have the K&N/DJ jet kit use DJ mains 148/150. Your friend should check the float level on his.
Old Apr 28, 2003 | 10:46 PM
  #17
wshrdskin's Avatar
If you use the dyno jet kit (K&N) don't use mikuni jets with it. GYTR has a jet kit out also, some just stay with stock needles and buy larger jets and are happy with that.
Old Apr 28, 2003 | 10:57 PM
  #18
SLIM660's Avatar
You can call dynojet directly and order any size jets you want. I ordered DJ jet sizes 155 through 175 five of each for about $50.00.
Old Apr 28, 2003 | 11:02 PM
  #19
wshrdskin's Avatar
Yes you can. I'll even help you out by posting the website. You want DJ style. They'll be at your door in a couple days from the time you order. $2 each.
Dynojets
Old Apr 29, 2003 | 05:58 PM
  #20
Thanks for all the usefull info. <FONT face=Verdana size=1>wshrdskin </FONT>what size jets do you use? Does it matter what elevation you are at? I ride at about 4-5,000 feet.
