Can someone help me with my (stock) Raptor suspension settings?
Old May 7, 2003 | 09:15 PM
Lboy's Avatar
Default Can someone help me with my (stock) Raptor suspension settings?
I'm 5'10" and about 185lbs.
Can anyone recommend tweaking the suspension settings from stock for any improvements?
I don't expect someone to be able to give me EXACT settings,but just wondering if I should mess with it at all?
I've bumped the rear tires up to 6psi to help a bit with the front end coming up in the woods,and its made a great deal of difference so far.
Would firming up the compression on the rear shock help?
Thanks for any insight anyone can give me.
Old May 7, 2003 | 09:22 PM
RacinJason's Avatar
Mess with your suspension all day and all night...its a great way to build confidence. I'd recomend that you tighten your spring...
don't be timid, make some adjustments then ride it, make some more adjustments...
Old May 7, 2003 | 09:48 PM
Psycho's Avatar
Yeah...what JAY said. Take a day to adjust it softer. See how it rides. Then harder. See how it rides. You'll be able to feel when you have it adjusted to your liking. [img]i/expressions/face-icon-small-cool.gif[/img]
Old May 7, 2003 | 09:52 PM
RacinJason's Avatar
air...are you saying to loosen the front shocks for big hits? If so whats the theory behind it?
Old May 7, 2003 | 09:59 PM
Psycho's Avatar
I found that having soft front shocks on big jumps will bottom-out the front suspension on landing, putting the sudden stop "shock" straight into my arms. Thats me, though, it could just be my jumping style!![img]i/expressions/face-icon-small-smile.gif[/img] Not to mention the bulldozing affect on jump approach!!!
Old May 7, 2003 | 10:05 PM
Lboy's Avatar
Thanks for the advice,I'll play with the settings and see what happens.
Old May 7, 2003 | 11:25 PM
warrior86's Avatar
im 5'11 and about 160 and i just tightened my front suspension all the way as tight as they can go. I have nothin but praise for the results. Is it definately more stable. before the adjustment i was extremely hesitant even to do donuts because the suspension would dive so much on a turn. Now when the rear comes up, the rappy stays stable. Also, coming off a 4 foot cliff (if u would call it that) i bottomed out the suspension before. Now it is much better. To be perfectly honest, i wish it was even stiffer. i tightened the rear a little but not to the extent of the front.
basically, if you like a soft ride to cruise at that feels like your on a boat, leave the suspension alone...if you ride hard and want better handling, tighten those babies up! good luck, warrior
Old May 8, 2003 | 04:50 PM
Lboy's Avatar
If it ever stops raining,I'll probably go out and try it at both extremes...soft and hard......to get a feel for how the bike reacts at those exptremeties.
Then I guess I'll tune it to where it feels best for me.
Thanks for the info and advice.
Old May 8, 2003 | 05:56 PM
warrior86's Avatar
yeah tell me about it. Its practically been raining every weekend since i got my rappy...even the day i picked it up. Im soooo sick of this!
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
Asaran
Oct 8, 2015 11:14 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
