Raptor gearing
Old May 9, 2003 | 04:18 PM
mugsy's Avatar
Default Raptor gearing
How many of you are running the 12/42 combo on your 02/03 Raptors? I have a 12 tooth front sprocket and it seems to have geered me down a little to much. Would I benifit by going to 42 rear or does it make tha much difference from stock. thanks
Old May 9, 2003 | 04:27 PM
warrior007's Avatar
13/40 here.
The 12t was a hot ticket on the 2001, I couldnt see gearing down to 12t now with 2002 gears.
Old May 9, 2003 | 11:51 PM
BigScary's Avatar
if you put the 42 on the back that will gear it down worse..........
I would go with the 13/42
Old May 18, 2003 | 01:24 AM
3GROC's Avatar
I have an 03....with full LRD, pro design intake and twin air filter and just put on a 14/40 (had to take case saver off). I work at a dealer so I found an old 5 dollar JT sproket that was for an older YZ400 or MX soemthing or other and ith as the same splines. if you have mods like this I definitley recommend it. the top end rush this quad has now is amazing. it just kept pulling. I had 12-40 for the longest time and just did it for fun....best 5 bucks I spent. Id rather get a 13/37 goin or 38 so I can put my case saver back on but for now it is staying.
Old May 18, 2003 | 01:30 AM
ChubbyNug's Avatar
I am running the 12 tooth on the front with the 42 on the rear and I mainly go to the dunes, really torquey but awesome for climbing...
NuG
Old May 18, 2003 | 01:59 AM
SLIM660's Avatar
14/38 OR/14/40 DEPENDS ON WHAT I'M DOING. SLIM
Old May 18, 2003 | 02:03 AM
raptor8's Avatar
i run whatever is stock EXCEPT i went down one on the front to compensate for the 22" XCTs. seems to work fine to me.
i did the opposite on the blaster when i changed to 20 XCRs on the back...it goes fast enuf, and i dont have to fry the clutch to go slow...
Firefighter400
Oct 8, 2022 06:38 PM
Ashley S
May 29, 2017 10:54 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
black_thunder
Jul 9, 2015 05:58 PM
