what can i do?
Old May 11, 2003 | 04:19 PM
BENNYBOY's Avatar
Default what can i do?
how can i fix up a blaster to go pretty fast with a small budget?
how much does a toomey pipe caost?
how much do bigger new tires cost?
Old May 11, 2003 | 10:00 PM
crispy's Avatar
well bennyboy,
to start things off I'd put an air filter in it, preferably a unifilter. you can probably get those at the dealership. it's about the cheapest way to go to ensure your engine life lasts longer. Pipes are going to be expensive, about 250$ and up. I'd say get a jet kit and an air filter to start off. that'll be about 120-150$ right there. hope it helps
you'll prolly get a 15 to 20% power increase
crispy
Old May 11, 2003 | 10:21 PM
SpinCycle's Avatar
you can change the air filter to a UNI/ K&N and get some good results but you will HAVE to change the main jet in your carb. If you have never done this find someone who has. If you get the air/ fuel mixture too far out you can smoke a piston... As a matter of fact, take the lid off the air box as well... then rejet[img]i/expressions/face-icon-small-smile.gif[/img]
