2009 Can Am DS 450
2009 Can-Am DS 450
For 2009 Can Am returns to the ATV scene with three versions of its venerable performance model, the DS 450. While technically introduced last year, the DS 450 X was touted for offering the lowest overall weight, lowest unsprung weight, most power and most centralization of mass. This year, Can Am has refined the X concept even further with two new terrain-specific models. Beginning with the (still available) 99 standard model, Can Am added a whole host of aftermarket goodies in creating the 50″ wide DS 450 X mx and the tight-wood racing DS 450 X xc. All of these models boast race-readiness right out of the box.
The DS 450 Standard:
(Featured Above)
(Featured Above)
- Rotax 4-TEC 449cc, liquid-cooled, single cylinder 4-stroke
- DOHC 4-valve head
- 97 x 60.8 mm bore and stroke
- EFI with 46 mm throttle body, 16 bit CPU with 32 MHz clock speed
- Electric start
- 5-speed manual transmission
- Chain drive with rigid axle
- No weld, ALTEC twin pyramidal aluminum frame
- R-Type forged aluminum double A-arm front suspension
- KYB HPG aluminum piggyback front shocks with compression and rebound clickers, threaded pre-load adjustment and 9.5″ (241 mm) of travel
- R-Type cast aluminum swingarm rear suspension
- KYB HPG aluminum piggyback rear shock with adjustment for compression, rebound, spring preload and 10.5″ (267 mm) of travel
- ITP Holeshot SR front and rear tires
- Polished aluminum wheels
- New headlights for 2009
- New color option – Can-Am Red
– Manufacturer Suggested Retail Price (MSRP): ,499 USD
DS 450 X xc
All the standard DS 450 EFI features, plus:
- R-type forged aluminum double A-arms with adjustable caster
- KYB HPG C36 aluminum piggyback front shocks with dual-speed compression, rebound and preload adjustments and 9.6″ (245 mm) of travel
- KYB HPG C40 aluminum piggyback rear shock with dual-speed compression, rebound and preload adjustments and 10.5″ (267 mm) of travel
- 7.5″ (190 mm) factory-set ride height (175-lb rider)
- Adjustable-width hollow rear axle (from 46″ [1.17 m] to 50″ [1.27 m] by increments of 0.5″ [12.7 mm] per spacer)
- Extra-strength extended 1″ (25.4 mm) steering stem with anti-vibe mounts
- 21×7-10 ITP Holeshot GNCC 6-ply front tires
- 20×10-9 ITP Holeshot GNCC 6-ply rear tires
- Black aluminum ITP 10×5 T-9 Trac-lock front wheels
- Black aluminum ITP 9×8 T-9 Trac-lock rear wheels
- 3-mm full aluminum chassis skid plate
- 5-mm full aluminum swing arm skid plate
- Aluminum nerf bars with removable heel guards and side extensions
- Aluminum 6061-T6 taper-profile handlebar with square pad
- Aluminum front bumper, number plate ready
- Handlebar wind deflectors
- X package seat cover
- X xc race graphics
– Manufacturer Suggested Retail Price (MSRP): ,749 USD
DS 450X mx
- + 2″ double A-arms with adjustable caster and camber give a 50-inch front stance
- Kashima-coated KYB HPG C40 aluminum piggyback front shocks with dual-speed compression, rebound and preload adjustments and 10.7″ (272 mm) of travel
- Kashima-coated KYB HPG C46 aluminum remote reservoir rear shock with dual-speed compression, rebound and preload adjustments, and 10.7″ (272 mm) of travel
- 7″ (179 mm) factory-set ride height (175-lb rider)
- 20×6-10 ITP QuadCross MX PRO front tires
- 18×10-8 ITP QuadCross MX PRO rear tires
- Black aluminum ITP 10×5 T-9 GP front wheels
- Black aluminum ITP 8×8 T-9 Trac-lock rear wheels
- X mx race graphics
– Manufacturer Suggested Retail Price (MSRP): ,949 USD
For more on these or all of Can Am’s 2009 lineup: http://www.can-am.brp.com/en-US/index.htm
