How do i adjust the valve clearance on a 300 Arctic ATV
Old 01-14-2007, 10:21 PM
Newfieguy's Avatar
Default How do i adjust the valve clearance on a 300 Arctic ATV
Hi,I am new to this site and would like to know if anyone can help me out with adjusting the valves on a 1999 Arctic Cat 300 ATV? Also what is the correct valve clearence?This is a bike I just bought and it wasn't running when I bought it and I did a compression test and it only had like 40 to 50 psi.I then backed the valves of a half turn and it shot up to 120 psi.This is why I would like to know what I should do to correctly set them.Also where could I find a wiring diagram for this bike? Thanks in advance for any help you guys could be.
Old 01-14-2007, 11:52 PM
Bear4570's Avatar
Just down load the service manual on the "2001 Artic Cat 250 service manual " thread and it will tell you how.
Old 01-20-2007, 06:09 PM
Newfieguy's Avatar
Thanks bear got the manuel down loaded.
Sjrpp
05-02-2023 03:59 PM
slowgsxr97
03-18-2022 03:40 AM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
Hankey Pankey
05-01-2018 01:33 PM
Quick Reply: How do i adjust the valve clearance on a 300 Arctic ATV
