oil change
Old 04-25-2009, 06:35 AM
brithan's Avatar
Default oil change
Is there any way to get all of the old oil out of a 2000 AC 300 4x4? I realize that the engine is the oil cooled model but even after removing the drain plug and installing a new oil filter the oil still seems kinda dark to me. I was thinking there was still old oil in the cooler lines and cooler.
Old 04-25-2009, 09:21 AM
mudslinginfool's Avatar
Does it in the Mud!
maybe try to disconnect the lines to the oil cooler and let them drain,but i dont think its worth it. Id just change it a little sooner next time if your worried about it. If you think about it,you put 3qts in it,thats alot of new oil.
Old 04-26-2009, 01:58 AM
swampyjunior's Avatar
I have drained the oil out of the oil cooler before by removing a hose. Then I discovered a large plug on the bottom of the cooler. Never tried it though because even then the oil still seemed to stay a little colored. I then looked at the AC oil I was putting in and it had a greenish brown tint to it. I think once it mixes with a little bit of the old oil in the motor in gets darker. Make sure you change the filter with the oil and clean the pick-up screen. I have not bothered to drain the oil from the oil cooler since.
I usually put just over 3qts in with a filter change.
Old 04-27-2009, 09:21 AM
Rude Robert's Avatar
if money is no option u could fill with fresh oil, then redrain it and then put more new oil in it
ReconBayou
10-31-2022 05:37 PM
Jackg17
Ask the Editor
07-16-2018 04:01 AM
Alex G.
09-11-2017 11:38 PM
Gwolf228
02-18-2017 01:36 AM
Jackg17
09-26-2015 09:30 PM
Quick Reply: oil change
