Gear indicator Lights
Old 11-17-2009, 08:32 PM
tbent4098@sbcglobal.net's Avatar
Default Gear indicator Lights
I have a 2002 Arctic Cat 500 and the third gear indicating light bulb is out. Does this cluster come apart easily for bulb replacement, any tip would be helpful. Thanks , Tom!
Old 11-18-2009, 05:49 PM
swampyjunior's Avatar
I believe you can either take the instrument pod a part to get at the wiring harness and lights for the pod. But since your machine is a 2002 it should still have the analog speedo right? So try seeing if you can pry the rubber part up that has the neutral, temp lights that is in the middle of the pod. I accidently pushed mine in with my elbow as as I was using it as a rest for my rifle to shoot a bear.
For me it popped in and I was able to pop it back into place. You may be able to pop it out and access the wires/lights. But upon looking at the parts number list I only see part #0420-034 LED Panel which is about $90. So I thinking you can not replace individual lights?
Hope this helps
SJ
skinnyr6
08-25-2023 02:18 AM
bzdok1234
30
02-23-2016 01:55 PM
micheleLeigh
Technical and How-To Articles
07-19-2015 07:32 AM
KimSJoh
14
07-18-2015 07:20 PM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Quick Reply: Gear indicator Lights
