1999 cat 250 2x4 keeps fouling plugs
Fundamental internal combustion knowledge base. You can not go to a larger jet unless you improve your exhaust. If your trying to cure an off idle lean condition then low speed jets up one size at a time with stock exhaust untill the lean sputter goes away. If the main was enlarged then the exhaust needs to be opened up, this may create more noise than results. The jet may be to large. If you won some good screw drivers (craftsman, MAC, Snapon) you can swap out jets in about 10 to 20 minutes. Do this on a clean work bench out of the weather.
Hankey Pankey
05-01-2018 01:33 PM
Hankey Pankey
08-17-2015 05:01 PM
