Artic Cat Head Scatcher
Hey guys, I have an artic cat 400. I am working on top end,replacing piston set with minium bore in cylinder plus gasket set. Having a problem with (TDC) top dead center on crank. I did align the cam marks up as I was tearing down and piston seemed to be on compression stroke. How do I check to make sure piston is in the right possition along with cam? Where is the marks on the crank? Any help will be greatfl,thankyou in advance.
this is a link to the manual....http://www.mymowerparts.com/pdf/Arct...ce__manual.pdf
The tdc inspection port is above the rotor/flywheel, in front of the starter housing.. see page14 in manual. ( section 2).. good luck
jrooker6
04-23-2016 07:36 PM
Quadzilla Heritage
09-25-2015 01:39 PM
09-23-2015 06:23 AM
