1983 185s wont run at high speed
Old 04-14-2010, 09:52 PM
hmatthew8's Avatar
Default 1983 185s wont run at high speed
I purchased a 1983 185s from a neighbor, said it ran great last year. Fires right up when choked. when i unchoke it however it runs really rich and wont throttle up.. sounds like its bogging out. I thought it was a bad carb since a very good cleaning didnt help it and replaced the carb with a new aftermarket. It does the same... what can I do to fix this? and yes i've already adjusted the fuel mixture to the correct settings and i've tried the needle at different heights. im between 4-5k feet above see level.
Old 04-15-2010, 10:58 AM
rjdad's Avatar
Sounds as though the flow of gas to the carb is obstructed somehow. Have you checked that?
2quiker
03-22-2022 08:36 PM
mywifesquad
8
09-21-2015 08:20 AM
Steeldon
09-09-2015 09:38 AM
black_thunder
09-06-2015 04:41 PM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Quick Reply: 1983 185s wont run at high speed
