Kazuma Falcon 110 Bolt Pattern
All you need to do is measure the bolts and how many. Measure the distance between two bolts on center. It will be something like 110cc. If it has 4 bolts, then the code used is 4x110. Do this for both front and rear. That will help identify wheels that will fit.
Then you need to look at the tire to see the tire size, front and rear are often different.
blueandy88
08-30-2015 08:26 PM
