Panther 110 bc quad won't fire
Old 11-14-2013, 04:47 PM
1deeredr's Avatar
Default Panther 110 bc quad won't fire
5 wire cdi system doesn't fire. Ran troubleshooting tests found in someones post.
#1:357 ohms
#2: 124 ohms
#3: 49 vac
#4: .28 vac
A: .5 ohm
B: 0 vac until wire is unplugged from ign coil. .34 vac with wire unplugged from ign coil.
won't run with kill wire removed from connector. This has been intermittent until now. Any info or suggestions will be much appreciated!
Old 11-12-2014, 01:01 AM
chuckinnc's Avatar
Default My Panther 110 done the same
I unplugged the rear cutoff sw and remote start/alarm box, now it runs, here are some
measurements I made on the CDI box, mine is a 5 wire. Here is the connections if you are looking at the connector on the CDI box.
Cut the #4 middle wire and that will remove any
of the kill switches, handlebar, ing sw, (remote and rear saftey) if you have them.
1. Yellow/Black Top LEFT 78 ohm
2. Blue/WHITE TOP RIGHT 150 oHM
3. Red/Black Left botttom 365 ohm
4. Grey wire (bottom middle) is kill switch in ( turning ing key on opens this circut )
5. Green bottom right GROUND
2 1
5 4 3
Cole Hadden
08-24-2020 11:11 PM
Frisky2050
04-09-2020 11:19 AM
95wolv
07-17-2015 08:13 PM
ghost civic
07-15-2015 10:48 PM
J-Mack
Polaris Side by Sides
07-04-2015 04:19 PM
Quick Reply: Panther 110 bc quad won't fire
