Will these tires fit my stock rims??
I would think if stock was 10 inches wide and you went to a 12.5 inch wide tire and did not put wheel spacers on your tires would rub on your suspension.
An easy way to get a better estimate it to measure the distance between any frame parts, fenders, etc. and your current 11inch wide tires. You want at least 2 inches of clearance so mud won't build up and rub on anything.
SJ
SJ
Thanks for the advice. I never even thought of that. The tire will not rub on anything but the mud might build up in a few places. I will need to buy spacers. Now my question is, will these 12.5 inch wide tires fit on my stock rims? Will they fall off because they are too wide or anything? I am looking at the Interco Vampires and the skinniest with i can get for my rim is 12.5 inches wide. I am unsure if this tire will properly fit my rims.
Thank you for clearing up the wheel spacer thing for me! =)
I just looked up my stock tires on the internet. The stock tires require a rim that is 8 inches wide. The Vampires that i would like to buy requires a rim that is 9 inches wide. So my stock rims must be 8inches wide. Do you think I'd be able to get by with putting the Vampires on my stock rims? or is that a bad idea?
