top speed of an 09 trx 400x
#21
Judging from half the comments here I wont post any thing use full because it seems like a waste. With thaat said. lol
Hawkman- Jet kit regulates your fuel / air mixture, how much of each get into the cylinder ... If your not evan sure what a jet kit is dont attempt to do it on your own. Call your local shops and see what they would charge you to pipe and jet your quad.
Check out denniskirk.com or rockymountainatv.com for pipe /jet kit combos.
pipe /jet kit combos are dyer to let your bike run at its full potential.
Great pipes for ex=
White brothers
Big Gun
Pro Circuit
Yosimura
FmF
Great pipes for ex=
White brothers
Big Gun
Pro Circuit
Yosimura
FmF
#22
#24
Im not even going to begin to explain why a carb can have so much influence on response and quickness if set up correctly on a stock engine with the right pipe, because you allready know so much huh...Guess my 15 years of racing experience and hundreds of manufactures ,shop gurus, mechanics, and gear heads have been wrong all these years.... But hell what do we know were just professionals...
Learn a few things then when you try to post something useful, it might actually be something people can learn from next time! Until then...
Unsubscribed
#25
^Any one that knows anything about engines and carb setups are laughing about this post!
Unsubscribed
Unsubscribed
Throttle response and QUICKNESS will be affected by all mods, but if you do not change the rev limiter and or gearing the quad will not be faster
ie: TOP SPEED!!!!
Why don't you learn a few things in all your years of experience, jackass!
#26
#27
Red is correct. I have many years of racing behind me. Go Karts, not ATV's. Top speed will not change unless the rev limiter is defeated or removed, or the gearing is changed. But, how FAST you GET to that limiter is a measure of quickness. There are proffessional football tackles that are QUICKER than sprinters. They can run 40 yards in less time. But the sprinter will run the 440 in less time. I know, not a good comparison but...... But I think Pimp just assumed the OP thought fast = quick. Don't be so hard on him Red.
#28
#30
