2001 Honda TRX250EX No Power
The splines have gone in the hub. If you are lucky you will just need a new hub, but if the shaft splines have gone, either weld the hub on, or buy a new shaft. The hub has to come off to change the rear wheel bearings and you won't be able to if you weld it on. Also the 250 rear brake drum has a nasty habit of seizing onto the shaft and it is a lot easier to get off if you can slide the whole shaft out.
