Recon
Recon
I purchased a 2005 recon yesterday. They said it needed a new carburetor. I get it home and pulled the carb, fuel tank, fuel lines and completely cleaned whole fuel system. Go it started but will only start and stay running on full throttle. Sounds terrible. Popping out the exhaust and noise in the motor. Sounds as if it has compression lost. Any pointers would help. It's a lil project with my son so it makes it important to get it fixed. Should I rebuild the top end? Thanks!
I checked the compression last night, it was a lil bit over 100. Ran it for a few then killed and wouldn't start. Done a compression test today and I'm at 60. Put new carburetor and spark plug. I pulled the top end tonight and it's very clean and looks really good. I will measure the clearance tomorrow and start all over. Thanks for the response, advice helps. And this is my first one I jump into.
