Eton 90 - electric shift sensor testing?
Old 11-03-2013, 06:10 PM
swfleur's Avatar
Default Eton 90 - electric shift sensor testing?
Calling all ETON owners that have any suggestions on the electric shift
I have a question about an Eton 90 that I am trying to get running.
It's a Rover 90 but I think the 90 viper uses the same wiring and CDI
It has the electric shift and the muti-wire cdi
I did get a copy of the manual and searched many websites with no good results
I figured out the spark and the neutral position and the brake needing to all be in correct state for getting the starter to work
This has the electric shift and the schematic or manual doesn't show what is going on with the voltages to the shift sensors? When I bought this machine used, there were many pieces removed. The electric shift motor was removed and not working. I put it on the bench and finally got it working ( brushes )
I'm wondering where the shift sensors are at for position and how to bump the shift motor so it goes back to where it is supposed to be - the prev owner had hot wired 12 v to the shift motor and so I'm trying to get things back to normal.
Is there a way to test the CDI?
Is there a way to test the Magneto coils?
What voltages are being switched by the position sensors inside the tranny? ( positive 12v or negative 12v) ?
I have mounted the shift motor back into the tranny and tried to use the toggle switch shifter to make the motor spin ( didnt work )
So I bumped the shift motor with 12v dc in either direction - hoping the indicator lights would light up if I got the tranny in the right place ( didnt work )
I may need a CDI but if anyone has any helpful info - it would be appreciated very much
Please help and Thank you
Old 12-04-2013, 06:41 PM
funatvs's Avatar
check anythingatv web site they somthing on there about the shifting. I had a viper 90r it would run but not shift it was the cdi box
COFatboy
05-02-2020 12:06 AM
Ripinandtearin
1) Engine problems..
12-11-2017 08:06 PM
sweaver
11
08-18-2015 03:47 PM
jldominic
Honda Side by Sides
08-08-2015 06:54 PM
Ripinandtearin
07-19-2015 08:38 PM
Quick Reply: Eton 90 - electric shift sensor testing?
