starts with kickstart but not starter
Old 04-19-2014, 08:14 PM
loumac's Avatar
Default starts with kickstart but not starter
Hello everyone,
I could use some help please. I bought my son an 05' Eton 90 not to long ago. be riding if around the yard a couple times and we finally got a good weekend to do some real riding. we were having a great day until his bike started craping out. we brought it home, i pulled the air filter, cleaned the carb and reassembled everything. i cranks when pulling starter button but wont start. if i use the kick start it runs fine. also runs with no problems when riding now, but occasionally will die when it is at idle. any thoughts as to why i can kickstart it but not start it with the electric starter?
Old 04-20-2014, 07:54 AM
First thing I'd have the battery load tested. Plus these little ones should be charging at least 13 volts back to the battery while at an idle. If not a regulator may be at fault not keeping a battery charged. They can run without a battery,but need a good charged battery to electric start.
Old 04-20-2014, 08:08 AM
LT80's Avatar
LT80 Expert
If that's all good, do a compression test.
Old 04-22-2014, 11:46 AM
loumac's Avatar
Thanks guys, i will check those things out this weekend. i appreciate your help.
Old 04-27-2014, 01:28 PM
loumac's Avatar
well, not what i wanted to find out but now i know what i need to do. compression came in at 70 psi where it should be between 90-120. looks like i got a top end to rebuild.
tiresharkdbb
09-03-2017 02:06 AM
02Chevrolet
1) Engine problems..
06-23-2015 12:12 AM
clsharky
06-08-2015 11:38 AM
vipers
05-31-2015 09:12 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: starts with kickstart but not starter
