Gear select.
Old 03-05-2017, 09:33 AM
Whitetailhunter8955's Avatar
Default Gear select.
Hi opt
2007 polaris sportsman 500 efi most of the time does not recognize park and today it didn't want to recognize reverse or park... after I drove it for 5 min it would display park and reverse. Any ideas opt?
Old 03-05-2017, 09:49 AM
Usually cause by the gear position sensor on the gear case. Clean the connections up and see if it helps. If not could be a speedo problem or the pins in the harness may need to be cleaned. They may not be making good contact.
