Sportsman 500 EFI turns off
Also its 500 efi 2006
It looks like its some of the sensors that made the atv stop
And we checked the fuel pressure gauge, somethimes it came fuel and it didnt come..
How can i reset the engine, it pops up with : check engie
Look at your manual on checking codes on the speedo. If it shows 41 or 45 could be the old T-bap harness problem. Look at the "sticky" about efi problems in the expert section. Plus if you have a correct auto fuel pressure gauge, then the 39 psi fuel pressure should hold continuously, if not you could have a weak fuel pump causing the dieing when warm. When the problem is resolved you can unhook the battery negative cable for about a minute and the check engine light and codes will be cleared. OPT
bzdok1234
30
02-23-2016 01:55 PM
