I am stuck. 1997 sportsman wont stay running
#21
So I checked it out a little before work today. Wires look ok and the more I mess with it I can get it to electric start intermittently but can't pinpoint cause. Very frustrating. Are u aware if I can bypass key switch successfully to determine for sure were problem is. Hate to just shoot another part at it and get same results
#22
#24
#25
Polaris is real nice about making all switches easy to disassemble and clean contacts and put a little dielectric grease but still didn't fix problem. So I used jumper wire to send power down white with red stripe wire going to start solenoid and will start and run
everytime. So I'm not using green push button to start. I just can't believe that it would be left side switch there is nothing to them when I took apart????
#26
#28
#29
Did you leave the black wire unplugged?? It receives it's signal to over ride when from the etc switch in the throttle housing.
